n Axle Diff Fluid
Union, MO
I have an '03 Dodge Ram 2500 2wd with an American Axle LS rear axle. Up to this point I have been using the Mopar specific fluid for American Axles. What aftermarket diff fluids are available which meet the AA/Mopar spec. No Amsoil please.
Many Thanks
I believe it specs a GL-5 synthetic 75W-90. So you could use Mobil 1 75W-90, Pennzoil Gear Plus Super 75W-90, Shell synthetic 75W-90, or many others including, Schaeffer's, Royal Purple, Red Line, Chevron, and even the one you said not to mention, which happens to be a very good gear oil. All of the above gear oils have the LS additive in them.
Do not use conventional mineral oil based gear oil, i.e., 80W-90.
I might add in 2003 the factory fill gear oil for Chrysler was made by Mobil, but Shell got the contract for factory fill in 2007.
I find it funny how the ford 10.5" calls for 75/140syn, but most other axles, even bigger axles, require 75/90syn.
Delvac 75w90syn meets a lot of standards and is a "thick" 75/90. I called the Tech line and they said you can add Friction Modifier if you need it, no problem. Which what I'm debating running in my Visteon 10.50" 3.73 LS.
Many Thanks
I believe, as Johnny said, that it calls for a 75W-90 in the 2500's. A 1500 would call for 75W-140. Royal Purple MaxGear works GREAT.
