Mystik 15w50 JT8 CI4+ SemiSyth
Ga
Blackstone report 6/19/2008
No elements Aluminum through Sodium.
Calcium 1100
Magnesium 964
Phosphorus 865
Zinc 1063
SUS Viscosity@ 210f = 89.4
cST Viscosity@ 100c = 17.83
Flashpoint F = 425
TBN = 10.0
Opinions?
Originally Posted By: Johnny
If those numbers are correct, it does not impress me at all for a CI4+ oil.
Very low calcium, zinc, and TBN
X2...nothing to wright home about.
Interesting, Blackstone's numbers are lower than Mystik's data. This is a reply I received from Mystic concerning the additives.
Thank you for your inquiry to Mystik Lubricants.
The following are typical properties on Mystik JT-8 15W-50; Phosphorus 1050 ppm Zinc 1280 ppm Magnesium 1060 ppm Calcium 1220 ppm
Hope this helps in your evaluation.
Also, the TBN on the Mystik website for 15w50 JT8 is indicated`at 11 not 10, Viscosity at 100* C cST is 19 not 17.83 and so on.
Would Blackstone's numbers be questionable or is Citgo being optimistic? I would have to agree it is not an impressive CI4+ oil.
I would trust Blackstone's numbers over the possible quality control issues associated with a Citgo product. Did you shake the bottle before pouring the sample?
Gave the two gallon jug a good shaking prior to drawing the sample. Caused some concern with the family which was hard to explain.
Thanks for the analysis and post. Valuble information to have. I guess I can take that off my list of oils for the bikes. Citgo huh? Now Chavez is trying to kill my engines. I don't think I like that guy.
Originally Posted By: ConfederateTyrant
With the amount of UOAs on here that include posts about how Blackstone tends to show low additive numbers, I think I'd trust Mystik over this one.
Yes, something worth to consider!
Blackstone show low additive numbers for VOA from time to time.
