Interesting, Blackstone's numbers are lower than Mystik's data. This is a reply I received from Mystic concerning the additives.
Thank you for your inquiry to Mystik Lubricants.
The following are typical properties on Mystik JT-8 15W-50; Phosphorus 1050 ppm Zinc 1280 ppm Magnesium 1060 ppm Calcium 1220 ppm
Hope this helps in your evaluation.
Also, the TBN on the Mystik website for 15w50 JT8 is indicated`at 11 not 10, Viscosity at 100* C cST is 19 not 17.83 and so on.
Would Blackstone's numbers be questionable or is Citgo being optimistic? I would have to agree it is not an impressive CI4+ oil.
