My new Murray push mower
FWIW I use either the Briggs brand 30W oil or NAPA brand 10W-30 full syn. in those motors. Also, my valve adjustment was a little off (Exhaust tight, intake loose) when I did my first adjustment after 1 year. I give mine a new air filter every year, change the oil and sharpen the blade before winter sets in. Briggs says no oil changes but we all know better. Edit: that looks like an MTD deck and you can get replacements for a reasonable price around $100 USD.
Thanks for the links for the decks. I just run the same oil I generally run in my cars. And currently its 5w30 HPL pcmo so it will be getting that. My last MTD got little bit of everything including Napa and PennGrade racing oil 😆
First use today. This thing rolls with like 1/5th the effort as my old MTD so thats a major plus.
It likes to pump out debris and dust out by the right front wheel which covers the whole thing in stuff and already is covering the fan and the air filter in stuff...yay.
Overall I am happy with it. I may see if I can do something to knock down the dust and then also add a valve on the fuel line so I can run the carb dry when I am done mowing.
Decided I did not need SP for a trim mower (have 42” LT) - so grabbed this 150cc Briggs powered mower from Walmart for $248 - free delivery … 🚚
Appears to have a nice powder coating and easy to fold/unfold.
There was a trace of oil on the stick from testing - and it smoked for a while when starting first pull! I will keep the 10W30 X 15 ounce bottle …
Oh - Cut lush grass with ease in mulch mode 😉
(Has side and bag too) …
Nice Mower. I picked one off the curb with a similar engine several years ago and fixed it up/sold it. The carb was plastic and was less than $15 on amazon. They start easy and seem to run well. Do what you want on the oil front, in my experience as long as they're full of something slippery they run forever.
My 1988 or 89 MTD is starting to turn into swiss cheese. My dad bought it new, used it as back up mower until I bought my house 12 years ago then I took it. Deck on the other side (I forgot to take a pic of the rot) is just falling apart.
Anyways, I wanted my own from new so I grabbed this at Home Depot. I am currently waiting on my order of HPL break in oil to run it in on before putting into use. Also it has a foam air filter so Ill likely give that some proper Maxima or BelRay filter oil. Its a 140cc B-S ohv.
Did you look under the motor for a drain plug - guess this is the “oil fantasy series” and you have to tip or use extractor - no plug on mine …
Where is the bag? I like my old MTD rear bagger. Still got it under the front porch, but I haven't mowed in a couple years . Mice are likely nesting under the recoil/fan cover.
We seem to have a bit of clover and moss around the old log cabin now. Grows low, keeps bumblebees and bunnies happy. No "fake" grass = zero maintenance. Lawns can look nice - a great expanse of green carpeting, but it's not nature. To keep it green and growing, You spread deadly toxins in the form of fertilizer and weed and insect control. Not good for you or the environment.
I worked as a caretaker at a large church complex in the 70's. Mowed the lawn to about 3" tall with a Locke reel, detailed with a wonderful Lawnboy two-stroke. It was a dense, beautiful grass. It didn't lay over.
The following year I got fired for refusing to mow the lawn as short as the Pastor requested. I said it not a fairway and it is difficult to water adequately in the summer. I said it is going to burn. It burned. It was a beautiful lawn.
- Kenarco
No drain plug. I just tilt it onto its right side and lean it back slightly and it drains out the fill tube. Eventually ill looking into getting a small extractor to keep at home. I have a normal? Mighty max or whatever its called extractor at work.
So far these last few months it has been flawless. It does struggle a little if the grass gets tall and is wet...but so would any other mower. Ive actually noticed ive reduced my cut times by about 7min because it rolls so much nicer its easier to push along.
So far these last few months it has been flawless. It does struggle a little if the grass gets tall and is wet...but so would any other mower. Ive actually noticed ive reduced my cut times by about 7min because it rolls so much nicer it’s easier to push along.
Nice! Thanks for info - I might put a couple hours on the B&S oil - then have a wee bit of M1 EP 10W30 I can change it to …
I agree, engine oil of almost any type will be fine. Maybe even cold pressed olive oil. It's splash lubrication.
Murray is not high end. It will be OK but it's not a Toro.
But if it cut the grass and you are happy then that's all that matters.
If it develops a problem it will likely be in the drive axle. There is not much to go wrong with the blade. If I remember they don't really sell many individual parts for the drive axle besides the wheels. And the replacement drive axle will be the cost of a new mower.
Its a push mower, no wheels driven
They did away with oil drain plugs back in the 90's. Nobody was changing their oil anymore. You can still probably see a freeze plug on the block where the plug use to go. Now it's tilt and fill, if that. Nobody wants to get their hands dirty anymore. I remember putting my mower on wooden horses and draining the oil out thru the plug on the bottom. While there, take off the bade and run it across the bench grinder. People can't be bothered anymore. I read somewhere that Briggs wanted to start using lifetime oil in their engines. No such thing as lifetime oil. It's a gimmick to make you buy another machine.
Deck Here's a replacement deck. The price must have gone up since I was looking around last year but there may be cheaper ones if you look hard enough. Here's another Deck a little cheaper.
Some of the decks for older mowers cost more than they are worth. I have a twenty year old cub cadet zero turn in perfect shape just sitting because of the deck and spindles.
