Originally Posted By: Hokiefyd
Originally Posted By: dparm
You guys had a bigger course, it looks like. My fastest time was down in the 29s.
Yes, it was a different course. Looking at the pictures of your event, it looks like you pulled up to the scanner and then the green flag was a hard turn to the left. At the absolute least, our course was a mirror of yours, as we turned right. But yes, I'm sure the course was a bit longer one, and is likely customized to the venue.
How many times did you hit the rev limiter? They told us we probably wouldn't hit it in the Focus and would probably hit it twice in the Fiesta. I hit it once in the Focus and three times in the Fiesta. I just BARELY got it at the checkered flag in the Fiesta, but that's because I kept getting the last turn into the last straight perfect (by luck I'm sure). It was a hard left with a slight juke to the right just after, so I'd slow to set up for the left, ease on the throttle as I was coming through, go full at the apex and the right tire would push over to just BARELY make the green cone on the right side.
I was pushing up white chalk each time. So I used everything up. I'm lucky I didn't hit a cone, which is a 2 second penalty.
We were made to run the entire course in 2nd gear (basically get it rolling in 1st, then immediately shift to 2nd just before the start line), which proved to be just fine. I approached the rev limiter just once.
