- Joined
- Jul 10, 2022
- Messages
- 6,076
Some context: We have a 2002, Kenmore Elite 18.5 cu ft freezer on bottom. It was very nice in late 2002, seems to be real stainless steel unlike today's "finish" or "appearance." I found long ago, a magnet doesn't stick to it, and when I researched that characteristic, it meant more chromium and molybdenum and won't corrode. To me it just looked like it was high quality, vs. today's that even cost $3,000+.
Anway, the ice maker broke maybe 2012, no big deal don't care.
BUT, starting in 2016, one day, the refrigerator was warm. Hmmmm. From this point on, I learned hey, refrigerators defrost. That failed and evap iced up.
This began with using a hair dryer, getting it working again, finding the same issue in 3 weeks, and learning about this guy:
https://www.ferguson.com/product/bi...632842010-refrigerator-ww10225581/_/R-5152578
Changed it and seemed to be good again.
Unlike the first one, it wasn't 12 years later, but replacement OE thermostat failed in only about 3 years. Unit froze up and bought a non OE product, much less expensive.
When the same happened in 2021, I bought an evap fan OE, and a defrost timer, "just in case." And, sensors to monitor the temps in fridge and freezer!
So the last time I changed that defrost thermostat was last year. Now, I know the temps very well--this unit has a knob and a mechanical flap for the fridge. I hear when the defrost cycle kicks in as the compressor seems to stop abruptly and when I check the temp, it's not at its usual -5F, something random, and popping sounds ensue with the freezer rapidly gaining temp up to around 19F-22F depending on where it started from.
Because this fridge is smaller than normal, its price is jacked up. The newer model is identical other than the fact that today it has electronic controls.
https://www.bestbuy.com/site/whirlp...rator-stainless-steel/3928057.p?skuId=3928057
My biggest fear is shelling out that kind of money, and having an appliance break in a few years. If it would last 20+ like this one, I would be perfectly fine with spending the money. Until then, I keep monitoring temps. Heck, the bottom panel is not even screwed in anymore, I simply slide it out in case of it freezing up.
The thing I'll never understand--my replacement OE defrost timer says 3X per day.
This one clearly only defrosts 1X per day, and it's not 24 hours on the dot, something less. Curious if there is logic on top of the mechanical timer....
Again, to date, only the defrost thermostat has ever been replaced, but I have a spare evaporator fan and defrost timer just in case!
Anyone else go through what I have been since 2016?
p.s. we bought a chest freezer to supplement, can't get a full sized fridge into the basement, door not wide enough
