the toy trans are notorious for being picky even the latest varieties. i like and use amsoil products but i dont think you'll be happy with your results.. you can try the synchromesh mix or use a appropriate oe fluid or sf mtl-p or r. i've used the mtl-p and it worked fine. Pennzoil synchromesh can be found in az next to the other gear lubes in the same type of round bottle. to save you $ i'd be inclined to try the Synchromesh mix with what you have.
drew, for your clunk check your mounts closely especially the rear. you may have a torn/rotted out mount. i've seen that also happpen. you can remove and fill the mount or replace it.
