Hard to see the print ...... I think it says1929 . I havent used it yet . I have to figure out how to pair it . I'm running Ubuntu 18.4 if that matters .I don't think you need a dongle for Bluetooth - the bluetooth antenna is already inside your PC. I think your maybe confusing it with a standard wireless mouse - that has a USB plug in.
BTW - which one did you get and how does it work - been thinking of getting one as well.
Does your computer have bluetooth?I'm running Ubuntu 18.4 if that matters .
Go to settings (from the drop down in the top right) and bluetooth should be in the list. Click on bluetooth and it should give you a list of devices that are ready to pair. Click on the mouse and it should do its thing. As mentioned, if your PC has bluetooth. Most have for quite a while.Hard to see the print ...... I think it says1929 . I havent used it yet . I have to figure out how to pair it . I'm running Ubuntu 18.4 if that matters .
It says it cant find Bluetooth and to plug in a dongle to get bluetooth .Does your computer have bluetooth?
Maybe they used a Dongle before the PC makers started putting Bluetooth in computers .I don't think you need a dongle for Bluetooth - the bluetooth antenna is already inside your PC. I think your maybe confusing it with a standard wireless mouse - that has a USB plug in.
How is the poor thing going to reproduce.I just bought a new Microsoft Bluetooth Mouse and it didn't come with a dongle .
If you click on settings (from the top right drop down menu) is bluetooth on the list? If not, either your PC doesn't have it, or Ubuntu didn't load the driver on install. If it doesn't show up I would just search for the specs on that PC on the www to see. There is a way to find all hardware in Ubuntu - but I don't remember off the top of my head - I am sure someone else here knows however. My expert is at college currentlyIt says it cant find Bluetooth and to plug in a dongle to get bluetooth .
As others have said, if your computer already has Bluetooth it should be as simple as pairing the mouse.Hard to see the print ...... I think it says1929 . I havent used it yet . I have to figure out how to pair it . I'm running Ubuntu 18.4 if that matters .
I have an HP BT mouse that comes with a dongle and this mouse does not work without the dongle. Without the dongle and with BT 'on' on the PC the mouse does not show up. With the dongle, even with BT on the PC 'off', the PC sees the mouse.I just bought a new Microsoft Bluetooth Mouse and it didn't come with a dongle . The old one is a Logitech and has a Dongle . Is this common with some Brands ?
