Mounting pressure washer pump
Near the beach in Delaware
I bought a used Craftsman pressure washer with engine and frame for $35 I think. Nothing else. And I have a new AR pump I have had on the shelf for 10 years. Engine runs great.
Horizontal shaft. Standard 4 hole mounting. 5/16 fine thread.
The way the pump housing is cast the only thing I can use is a cap bolt for an Allen wrench. Not even room for a standard split lock washer.
Do they sell lock washers where the outside diameter is the same diameter as that of the head of a cap bolt?
Or Locktite?
Or keep my eye on the bolts?
loctite seems easy mode if you cant find something at ace.
Cat pump sells a 10ml locitite for only 1000% markup so I dont see an issue with using regular loctite.
So they are called high-hat split ring lock washers. Nothing local I could find.
Bolt Depot had them for $0.11 each plus $4 in shipping. While $4.50 seems high for 4 washers, it probably the same as some Locktite or gas used to find them locally if I even could.
The local ACE Hardware store than has tons of nuts & bolts in the usual drawers did not have these.
Bolt Depot did not require me to buy a bag of 50.
Finished pressure washer.
