I was wondering what the pro's and con's were of mixing Motul 300V 15W-50 4T with Mobil 1 0W-40 in a 50/50 ratio? Any thoughts?
Quote:
Have you seen the UOA of M-1 mixed with Redline 50/50. It was not pretty.
Quote:
What is AN?
Quote:
Why do people mix oils? Do they have knowledge about the makeup of these oils that is not usually disclosed? If one synthetic oil has a careful balance of additives that work together and take care of the seals, and you mix another oil with a different mix, could that screw something up. If one more shot of something will mess up the additive package of an oil and you supply it by mixing, what have you gained? And how do you learn about what you're doing if you don't know what you started with and don't run enough miles and don't tear down you engine to check? Wouldn't it be more interesting to get mugged standing in line to buy a Sony Playstation?
