roughly similar but uses sodium benzoate as the organic additive, it’s only found in primitive HOATs like G05 and toyota red.Where does the once-popular Peak Global Lifetime (PGL) fall in respect to the new Ford coolant?
Orange
https://www.msds.ford.com/documents/194810 E_GBEN.pdf
Yellow
https://www.msds.ford.com/documents/201944 D_GBEN.pdf
Both contain the tried and true organic additive, Sodium 2-ethylhexanoate in similar if not identical amounts.
The Transits had issues with plugging heater cores with the Orange-we had one partially plug, but it was able to be backflushed and converted to Prestone AMAM with Cor-Guard (which is the same as Yellow). My Transit has had slow coolant leaks since the day we got it, and it has been topped off with Dexcool (by me) and Yellow (by the Ford dealer) and has settled into a nice dark red Dexcool color with no issues (other than the endless annoying slow leakage).Ford told me they can be mixed. I am not 100% sure why they even changed it but I guess in the video above people had issues? I never did. My system was clean and never had any solid build up.
I did just do a radiator upgrade and changed the water pump in my 2014 F150 that came with the orange. Since I had most of the fluid drained from the engine anyways I decided to change to the yellow. Did a 40/60 coolant/water mix.
