I did a drain and fill on our 2017 Explorer with the 2.3 Eco Boost and the 6F35 transmission. It was the factory fill with 12,200 miles on it. I've been reading these transmissions tend to beat up the ATF early. It's ridiculously easy to change. I bought a 12 qt case for $60. I used almost 4 quarts for the change, 3.85 quarts to be exact. The attached photo shows the old Mercon LV on the left and the new Mercon LV on the right. The used Mercon LV was pretty dark, almost black at only 12,000 miles. I'm sending it to Blackstone for analysis, for S&G. We keep our vehicles for a LONG time and many miles, our 2005 Explorer has almost 194,000 miles with the original transmission which works like it did new. We've changed the fluid every 25-30,000 miles. That's a lot less expensive than a new transmission. I find it hard to believe that Ford calls for the first ATF drain and fill at 150,000 miles
. Amazingly that's well out of warranty
. I'll post the Blackstone analysis when I get it back.
Whimsey
Whimsey
