This filter was removed from my Dakota. It was the remote mount transmission filter I installed a year ago. This is the first spin on filter this transmission has seen so I thought it would be a lot more dirty. I suppose it being so clean is a good thing! The fluid was not changed at the time of installation, just topped off. The fluid that is in the transmission is about two years old with maybe 10 k miles on the fluid. I changed the fluid today and dropped the pan to change the internal filter. Used a Wix filter kit in the transmission and a Wix 51515 for the spin on filter. Filled with 7.5 quarts of Supertech ATF +4. The pan looked really good with not nearly as much hunk and sludge as last time. I'll probably change this spin on next year and a couple of years before I drop the pan again. What do you guys think??
