Originally Posted By: Jakegday
it also filters considerably worse then the fl-1a equivalent, the 51515. that is the reason i wont be trying one out
Why do you think it filters "considerably worse" than a 51515? I don't have access to the specs on the Wix series, but the Purolator equivalents have identical bypass pressures, and all Puro's use the same media so there's no way the Purolator 40017 is going to filter "considerably worse" than the 30001.
ummm, if you have the internet, the same service that allows you to post on this very website, then you have access to wix specs.
and speaking of specs, that is exactly what makes me think it filters considerably worse. i looked at the specs
Would it have killed ya just to answer the question instead of sending me off on a goose chase? I really don't CARE enough about the Wix version to go look (the Purolator version is obviously every bit the equal or superior of the 30001, provided it will fit), which is why I asked here.
