- Joined
- Aug 21, 2020
- Messages
- 211
Need to change an upper motor mount on my car. To do this, I understand that you need to relieve pressure on the old motor mount to unbolt it and take it off. My understanding is that you do this by supporting the engine up with a jack, using a horizontal 2x4 of wood under the oil pan.
Here is my question. Is there any risk that doing this will damage the RTV gasket that is sealing the oil pan? I had to fix this leaking oil pan not too long ago, and really don't want to do it again. Obviously the oil pan is not torqued super hard to the engine block, so there is a rubber layer of RTV between the two....
Thoughts?
Thoughts?
