I'm guessing it's not supposed to do that. Yours lasted longer than mine, but why only several weeks? Did you get it resolved?The concave protrusion and the mount “loosening up,” resulting in vibrations.
I doubt it. The engine is solid and the vibration is definitely due to the torque mount which was very much shot. The car is not undrivable now and it was perfect until the mount blew. The whole thing about him screwing up the timing/balance shafts was speculation and turned out not to be the case.Isn't this the one where the brother-in-law did the rebuild and possibly botched the jog? I ask because it could be that the motor really is hosed and destroying the mount? (I've only replaced about 3 mounts, and know it is easy to mess up).
So, replace all the mounts, even though they are all fairly new? Are you sure the torque mount won't work even if I install it correctly this time? The mounts are all pretty basic, unlike on the Murano-just rubber and metal.I agree with a previous post above. Replace *all* engine mounts/dampeners at same time. Use a floor jack and board(s) as needed to relieve all tension, install in neutral position. Use ratchet straps and a crow bar if you have to!
How do I know?
Picky as snot 1st gen. Nissan Murano with ferrous-fluid filled, electronically dampened engine mounts. *Zero* room for mistakes.
Zero.
Out of the realm of your casual weekend wrencher?
Not at all. Go slow, go safe, pay attention to details. And of course, you did mention OEM parts usage. I won't compromise on driveline parts either. But double check, make sure you're getting genuine bits inside the boxes. Reject any that are remotely suspect.
To be thorough this time through? I would. Again, anecdotal experience. Had to do a motor mount job on a Ford Focus wagon (XW4, if I'm recalling correctly)So, replace all the mounts, even though they are all fairly new?
My mounts aren't nearly that bad. They're less than 4 months old and the car only vibrates a little. This is not something I can afford/do myself.To be thorough this time through? I would. Again, anecdotal experience. Had to do a motor mount job on a Ford Focus wagon (XW4, if I'm recalling correctly)
Complaint from friend was an idle engine rat-a-tap-knock in gear @ idle. Especially when AC was engaged. The engine was just as loose as a goose's neck in the cradle. It would rock and buck all around when changing from forward to reverse gears, etc. It really needed all three mounts replaced. He had monies for one.
One.
I had to redo the job after replacing the worst looking one. The other two were so weak that it just shredded the dogbone up behind the oil pan in just a week.
He bit the bullet and brought me all three, FoMoCo branded and sealed. Did the job again with all three new mounts...
Not a third complaint in over 2 years now.
So my vote again, just be thorough and patient. Cheap fixes cost 2x as much... grab all your mounts and replace at same time. Level and stabilize the engine so you don't have to "draw up" the motor by the bolts. They should slip right in, rest in place, bolt down snug with just 3-4 uggah-dughas from your impact gun without having to pull up or push the engine down against your jack(s).
Profit!
Edit: and for goodness' sake, work carefully and slow. Engines are abysmally heavy. Work each mount one at a time and double check as you go along.
No wrecks were reported when I looked up the vehicle history.Has this car ever been wrecked? Even a minor one? Are you sure?
If the unibody isn't perfectly square in the front, a FWD vehicle will destroy motor/transmission mounts.
No way for me to tell, but the flimsy plastic front fender was broken when I got the car. It's just decorative, though.There are such things as unreported accidents.
Obviously something is not right here.
You may be right. It also makes a horrible metallic screech on cold startup sometimes (or I just notice it sometimes) It lasts about half a second. I don't think it's the drive belt. It's like a crunch/grind kind of noise.(Un) Balanced shaft is causing it
Might be the VVT phasers rattling away until they get sufficient oil pressure - not a hugely common issue like on Honda K-series. I have two neighbors with Toyota 4 bangers (1 Camry with the 2AZ and 1 with a Taco with presumably the 2.7) that have the grind/rattle at start. The Taco has it really bad, the Camry it only happens every so often.You may be right. It also makes a horrible metallic screech on cold startup sometimes (or I just notice it sometimes) It lasts about half a second. I don't think it's the drive belt. It's like a crunch/grind kind of noise.
