Originally Posted By: JHZR2
Thing is, Ive found that if Im just trying to flush the radiator (not the whole system), that inserting the hose in the radiator neck and opening the petcock at the bottom does a pretty decent job by itself.
Ive heard horror stories about those prestone systems cracking and causing leaks, etc.
I do like the procedure posted by Kestas, and that's basically what I do on my old F-150. There's plenty of room to work on everything, it has a petcock, the heater hoses are all easy to get to, and so forth. Obviously, other people aren't so lucky with some vehicles. My Audi isn't bad, but it's not as easy by a long stretch.
I've used those fittings in the past without any problems. I do, however, agree with what you say. Long term high temperatures won't do those fittings any favours. Secondly, I'm always a little unnerved by adding extra joints (and potentials for leaks) in any cooling system. Also, if I am being picky and wanting to use RO water, well, there's a pile of tap water that has to be flushed after using those fittings.
