MOS2 question.
Originally Posted By: Hollow
I'm really enjoying the fact that this thread has pretty much nothing to do with my original post.
For background read my post.
Otherwise,
Does any one have a recommendation on whether to add MOS2 to a 10k Quaker State Ultimate Durability run or a 5K Quaker State Advanced Durability run?
Either or.
Personally I'd run it as long as I could. Ive found that after the first treatment only half the dosage is required to maintain the achieved benefits.
Since my oil change and no mos2 added to this sump load I've lost mileage. The first 1000 miles mileage was the same but has dropped from 30 peak to 26,so I'm going to be adding it again,once the cera-tec does whatever it do.
Otherwise,
Either or.
After the initial treatment half a bottle seems to be what most of us are using. I noticed with my power washer and lawn mower after I change the oil if I fill up with straight oil and run the engine I can still see traces of the MoS2 on the dipstick or the drain pan when I change the oil again. That leads me to believe the product does coat or cling to engine internals and gets circulated with the fresh fill of oil.
what mileage vehicle do you add this to mostly ? I have a 2004 GMC 5.3 w/ 150k I use pennzoil ultra in and a 1997 sierra w/ 230k I use high mileage pennzoil in (it's way past 75k like the bottle states though, haha) .
