JHZR2
Staff member
Hi,
OK, a while back i posted about some hangng issues with my 4.0GB cruzer mini. I have a variety of files on the usb drive, and a large number of bmp and jpeg files pertaining to laboratory work that I do.
I believe that the jpg/bmp files cause a severe hang, and do so on all cmputers that I work on. what happens s that if I even want to open, modify, or rename a file, the programs used hang and operate exceedingly slow when working with these files. Worse yet, when I want to dismount the USB drive, I constantly am told that the device cannot be stopped at that time. Shuttng down the computer seems to make it OK to remove the device without data loss, but this is a real annoyance.
Previously, i was able to do the error check to see if there was any sort of issue with the files. However, when I open/modify these jpg/bmp files, on any computer, and then go to run the scandisk/error check on the usb drive, I get the statement that windows needs full access to the disk, and that some windows components on the disk are being used, do I want to run the check at the next restart. Windows components on my USB drive?!!??!? I dont think so...
I donthave any issues working with JPEG files on any other memory products, like my camera memory cards - it must have something to do with bmp files and jpegs soured from bitmaps.
I am really lost, I cant even run scandisk/error check on the drive, and I have to restart to get the thing out without issue. Scandisk never seems to find any problems when it is run, and the irus scanner doesnt find any isues either. Some of the files seem to open and operate just fine, while others bog down (despite file size always being the same).
What gives? Any ideas? Any suggestions?
Thanks!
JMH
Thanks!
JMH
