Mopar - Hellephant 1000HP crate engine
ohio
Mopar will be offering a crate engine called the the "Hellephant." It's a modern 426 Hemi engine with 1000 horsepower and 950 lb-ft of torque. Wonder what the Dodge Demon will run in the 1/4 mile with one of these in the engine bay?
Originally Posted by rooflessVW
4 days ago
I don't think it's much different from the Demon engine - just unburdened from cats and a powertrain.
Hellcat is a 6.2l hemi with a 2.4l supercharger.
Demon is a 6.2l hemi with a 2.7l supercharger.
Hellephant is a 7l hemi with a 3l supercharger.
they did say it's "only for vehicles older than 1976"... i assume that's their way of telling us it won't pass emissions...
4 days ago
Or the cars it will fit in....
Just dreaming of that engine in my Jeep! I wonder what the price will be? North of $15k? Then I'd have to put at least Dana 60's on there, a transfer case out of a Terex, and a heavy duty transmission from a Ram. I'd probably be looking at $30k, maybe a little more to get it right.
Well, I can dream, at least.
I doubt any stock application trans would hold up to hot rod use. The trans would cost as much or more as the motor at those power levels.
North of $15K. Well duh. WELL north of $15K. Probably closer to $50,000 or more.
pricing not announced yet, but expect it to be well north of the $20k they charge for the "Hellcrate"( Hellcat crate engine)
Hmmmm, very interesting....
https://www.roadandtrack.com/car-sh...llcat-crate-engine-taken-to-the-extreme/
The Chrysler Gen III Hemi has larger basic dimensions than GM's LS engine, so it's not a big problem to get it out to 426 cubic inches. It's bore and stroke are 4.125 x 4.0, which is identical to a GM LS7
What surprises me is they switched to an Aluminum block. The 707 HP Hellcat has an Iron block.
if i remember right the first year 1964, for the 426 hemi was a full tilt race engine. the street hemi 1966 was a little milder.
https://www.hotrod.com/articles/pit-stop-1000hp-capable-street-five-speed-manual-trans/
Here ya go. Not as expensive as the engine is likely to be. Even after purchasing the bellhousing and clutch.
