"Moly"
You wont see any real benefit from it in your Iron Duke 2.5.
The oil you are using is good enough. Maxlife has enough moly and zinc in its additive package to prevent wear in that engine.
If chevrofreak is correct and there's that much i doubt any more would be helpful,that old 2.5 will out live you 2 to 1,run a quality oil/filter and go.
but like department said few of us are running it with noticeable results,i think it's good thing for oil's lacking moly.
Valvoline states right in their data sheets how much additive their products have. It seems to match up pretty well with UOA and VOA.
would never doubt you chev,haha
Originally Posted By: sxg6
Totally unnecessary. Save your money.
So when a manufacture adds moly to there additive package it's a waist of money??
it helps,,check the used oil analysis section there are posts with before and after analysis with this additive,wear metals were decreased.
.. In that application , it would NOT be a waste, since it is part of a complete Recipe. Adding extra Moly would be like adding an extra Topping, or Frosting. Sure, ya dont need it. But it makes you feel better....
It probably WOULDNT make a lick of difference in MY Iron Duke. But to know there was more Moly..
Priceless. :D
Honestly though. i have a feud with my local NAPA, so since my car will not see one blinking difference with oor without it (As my oil has a perfect amount it seems,) I will not use 5 to get it.
Schaeffers chose to add extra moly to there mix,why? its good stuff.
and at $4 bucks not going to break the bank.
I agree.
Just need to.. go to the right NAPA....
Additional moly helps to prolong engine life on high loaded moment but i read some additive manufacturer warn against too much moly even organic one
I agree.
If they dont have it they should very well be able to order it,it's in there system.
Now now don't put words in my mouth. I have nothing against moly. I am against everyday joes adding stuff to their oil. Trust that Valvoline and additive package manufacturers know what they're doing, and that adding something like more moly might throw things out of balance and possibly do more harm than good.
Just replying to your "Totally unnecessary" comment,like you know with scientific evidence it won't work and people should avoid it just because you said so.
anyway it's all good i hear what your saying tho,i don't like snake oils either but i do think there's something to this moly.
