N novadude Joined Jan 16, 2003 Messages 1,548 Location Shippensburg, PA Apr 3, 2003 #1 What would you guys recommend?
MolaKule Staff member Joined Jun 5, 2002 Messages 25,122 Location Iowegia - USA Apr 4, 2003 #2 I use a mix consisting of 1 bottle Walmart's Oil Additive (blue bottle) and 1 pint bottle of Schaeffer's #132 for assembly lube and run-in.
S Steve S Joined Jan 20, 2003 Messages 18,447 Location East of IGO Apr 4, 2003 #3 I would use a recommended product . A special lube for cams . The first momentents of operation is important for the life of the camshaft.
H HammerDown Joined Mar 14, 2003 Messages 241 Location Glenolden Pa. Apr 4, 2003 #4 I use the Cam lube that comes with the Cam whatever it may be, the Red stuff or the Moly...for the Crank Cam and Rod bearings I use a little Lucas. Cylinder walls just a very/very light oil or WD-40.
