Hi guys,
I've researched a few used oil analysis and VOAs on different ATF fluids and it seems like none of them contains molybdenum.
I was thinking: wouldn't an automatic transmission be a perfect candidate for using molybdenum (I guess in form of MoS2)? High pressure, high shear zones, high temperature clutches and valves, and long drain intervals in modern transmissions would probably benefit from a sizeable amount of molybdenum (I suppose somewhere in range of 200-600 ppm, but that's just an assumption).
Molybdenum could provide great surface coating, thus preventing or at least reducing metal to metal contact under high pressure. It probably would also reduce famous metal shavings we can see on the pan magnets.
So the question is: why ATF manufacturers don't use it?
Maybe Redline, who is famous for high molybdenum amounts in their products, would have some molybdenum in their ATFs but I wasn't able to find any VOA or UOA to support this claim. I'm inclined to think that if no one has it, Redline ATF probably would not contain any molybdenum as well.
Or is it clutches which are made of special material which varies from one transmission maker to another would result in some kind of problematic shifting if coated or contacted with molybdenum?
What are your thoughts on that?
Regards,
Regards,
