I've read a lot about the factory fill fluid which is G052171a2. Some people seem to think it's too thin even for stock power levels and some have seen pitting on races when tearing down their transmissions. Either way it is like water when drained hot. I have no idea how it is rated at a 75w. I'd also love to know why they chose to use a sulfur based oil when the shift forks are brass. I see nobody bring this up. I hope the synchros aren't.
My car has 285hp/290tq and I got three gallons of this mobil delvac synthetic 50w from work for free. It has a gl-4 rating as required, but I read the mt-1 rating is not for transmissions with synchros. I just want to make certain it's not going to hurt the transmission in the long run. The car wont be driven in the winter. I want something that will be better suited for the slightly higher power levels. I don't know much about the cSt rating but redline mt90 seemed notchy at fifty degrees. I haven't tried the mobil yet at fifty degrees but it's in the transmission now. I know that redline makes other thinner fluids which i'll probably end up using or combining with the mt90 I have, but this mobil fluid seems like high quality fluid.
Apparently there are two different mobil 50 trans fluids. The one I have says gl-4 right on the 5 gallon pail.
https://www.mobil.com/English-US/Co...GLXXMobil-Delvac-1-Transmission-Fluid-50
