Welcome to the site!
Seems that any reasonably compliant oil will work given those specs. We know nothing of your OCI plan, but I'll presume you're sticking with OEM intervals (or more frequent). Also, I presume the equipment will be worked in a "normal" manner (it's farm equipment; it's made to be worked hard).
I would not limit yourself to only those two brands. I'd buy whatever is cheapest. If you can get the convenience of bulk buys from your Mobil sourcing (maybe even delivery) then the 1300 makes sense. But you could also shop around for your lube needs to to other marketers.
Do not presume that there is one "best" oil; it's just not true. But there are MANY that will do an excellent job, and then you can use cost competitive valuations to drive your decision.
There are some excellent, long service used oil analysis from sdan27 in the used oil analysis sub-forms; good information to glean from those. Brand/grade matters little as long as you pick a lube that is "in spec" for your applications.
