It’s 4.1. I looked it up last night. Kinda light for a 15w40I am wondering what HTHS of this oil is?
How did I missed that HTHS. I think that HTHS is pretty good for HC oil.It’s 4.1. I looked it up last night. Kinda light for a 15w40
Mobil also makes a Delvac Extreme synthetic 10w30 as well. Didn’t know about that. Not many synthetic options out there for 10w30, nice to know amsoil and RLI arent he only ones offering it now.
Where do you buy there products? Do they have an e-commerce site?High Performance Lubricants makes an HDEO in 10w30 as well. I'm running it in my Tahoe currently.
Does HPL pubically publish their PDS ? I clicked on the link at their home page and it requires a login.
Nevermind I found it here. Thanks
TBN of 4.7 on the first run and a rerun showed 8.5. That is a HUGE variance. Which value are you going to believe? The website's 10.3? 4.7? or 8.5? Does Blackstone have an explanation for why the variance is that big? Did they say it was a problem with the way you collected?The PDS on Mobil's website states that the TBN starts 10.3
I have serious doubts about the accuracy of the Blackstone results.
VOA and used oil analysis threads like this make me wonder if we are not being scammed and will push me towards changing the oil at a shorter interval.
I've been in HPL's lab and have witnessed the process of calibrating equipment before tests are run, including TBN. If you want repeatable and predictable test results, to say it is not trivial is an understatement.It shows that testing oil is not trivial and decisions should not be based on $30 analyses.
You can't run samples through quickly and expect accurate results.
And the ICP manufacturer's recommended calibration takes about an hour. HPL has designed their own calibration that takes three hours and give them more consistent testing results.Exactly. I know when HPL uses ICP in their lab, they will focus on each element for up to 5 minutes. The mass labs like Blackstone, ALS, and Polaris... 10 seconds each, 15 max.
