my #'s---avg#
alum 2---3
chromium 1---1
iron 33---15
copper 1---6
lead 0---1
tin 1---o
moly 147---47
nickel 0---1
mang 0---1
silver 0---0
titanium 0---0
potassium 1---1
boron 34---48
silicon 12---16
sodium 279---5
calcium 2472---2165
magnesium 8---199
phos 665---771
zinc 913---930
barium 0---1
sus viscosity@210f 56-63 --- 58.3 mine
flash 365 ------ 440 mine
fuel antifreeze 0 ---- ?
water insolubles tbn --2.2
COMMENTS
Robert; Normally when we find sodium in an oil it is from anti-freeze.in this case it may be an additive in this oil,which is mobil clean 7500.If the sodium was from anti-freeze we would expect to find poor bearing wear, and the metals from your bearings are perfect.We did find high iron wear, for an oil run in this type engine 3404 miles. our average oil sample from the 4.6 has 4400 miles on it,and iron wear averages only 15-ppm. your higher iron may show engine maturity, or there may be some sort of problem at steel parts. the TBN was 2.2,getting low.
Well guys i need info on this report please,this is my first oua and i guess the major thing here is the high iron and high sodium.of course this was mobil 7500 semi-synthetic that is good for up to 7500 miles they say? My oil with only 3404 miles had a TBN of only 2.2 left,i dont think it could go all 7500 miles,the oil was used for 3.5 months with mostly short trips and a few 25-plus mile trips the oil was gf-4 5w30 the only additive i put in there was an octane booster in the gas tank to clean the system i dont know if that made any difference in the way of the reading in this report?the additive was added in the middle of the run filter used was a napa gold.Right know im using trop artic semi-synthetic but i will just use it for 2k and then go with pennzoil platinum 5w30 full synthetic to see if things get better. thanks comments please?????????
alum 2---3
chromium 1---1
iron 33---15
copper 1---6
lead 0---1
tin 1---o
moly 147---47
nickel 0---1
mang 0---1
silver 0---0
titanium 0---0
potassium 1---1
boron 34---48
silicon 12---16
sodium 279---5
calcium 2472---2165
magnesium 8---199
phos 665---771
zinc 913---930
barium 0---1
COMMENTS
