Mobil 1 vs RedLine - Road Trip!
Thanks for the feedback all!
I elected to change it out anyways knowing full well it was pointless. Whatever, I had it on hand, had read good things about it reducing valvetrain noise in the VQ motors, and got bored! It was a good time to check for leaks and other wear, and I also had an upsize filter that I wanted to stick on there too.
Turns out the ADBV had gotten pressed open on the existing filter so there wasn't much anti-draining going on. Mobil 1 oil that came out was just starting to go dark/black and could have probably gone another 9k
[Linked Image]
Consider that Redline will be cleaning up the bits in your engine on that road trip !
You may want to go a bit shorter OCI on that Redline... at least check it for cleanliness or dirt. If it gets dirty that means it's doing it's job!
It cleaned up my 19 year old Z3 like crazy with an unknown OCI history
Redline is great stuff
[Linked Image]
[Linked Image]
No need to worry about that here
Still looking good down under
[Linked Image]
