Flash: 425f
TBN: 12.4
Iron: 1
Moly: 73
Boron: 246
Calcium: 2846
Silicon: 3
Sodium: 6
Mag: 15
Phos: 1588
Zinc: 1602
sus@210 59.5
No problems showed up in this sample of virgin 0w30. The viscosity was at the low end of the
30W range and right where we expected to see it. The 1 ppm iron isn't a problem and is actually a
common find in virgin oil (see universal averages). Boron, calcium, and magnesium are
detergent/dispersant additives, while molybdenum, phosphorus, and zinc are anti-wear additives. No
moisture or insolubles were found. The TBN read at 12.4, which is a strong reading and shows there is a
lot of active additive present. This is serviceable oil and should do well in your engine(s).
TBN: 12.4
Iron: 1
Moly: 73
Boron: 246
Calcium: 2846
Silicon: 3
Sodium: 6
Mag: 15
Phos: 1588
Zinc: 1602
sus@210 59.5
