High Iron again (34) on 15W-50 silver cap vs 28 on 5w-40 TDT last run. The TDT cut down a bit and this oil ended up about a 10w-30 so I am trying Valvoline VR1 20w-50 this time and may try Redline after that. I want to see if I can find a shear stable oil for 4000 or so miles. Not sure about the iron. NO gears or clutch in the oil and the block is Aluminum with NikaSil liners. The only oiled iron is the valve train, cam chain and gear driven oil pump and balancer shaft. It is a 4 quart sump for a 750cc "automobile type" engine...should be easy on the oil!
I live and work just off the interstate. I wonder if a half mile run before I hit 70mph/5000rpm is enough to lube the cams? I would think everything is oiled well by then, no?
![343j24x.jpg](http://i51.tinypic.com/343j24x.jpg)
