Mobil 1 M1-113A oil filter cut open
BrendanC
$100 site donor 2024
Houston, TX
2015 Chevrolet silverado 3500HD 6.0L Cab and chassis. 12ft lift gate bed. 35k miles
in service 6k miles
out/off: Pennzoil Platnium High Mileage 5w-30 with Mobil 1 M1-113A
in/on: 5 quarts Valvoline Restore and Protect and 1 quart HPL Engine Cleaner 30 with Carquest Extended Protection P84502
looks good, bypass valve looks different than M+H filters i’m used to. This filter was in service 2.5ish years.
in service 6k miles
Great work as always sir
Date code is 7/14/2022. This is a Purolator/M-H Mobil filter that doesn't use the flat spiral spring on the bypass valve. It probably also had a coil spring instead of a leaf spring.
