Mobil 1 Extended Performance Oil Filter Quality
Northern Va.
Generally speaking, is the Mobil 1 Extended Performance oil filter made of decent quality today??
Thanks for the answer, I appreciate it.
What are your OCI's like, if it is 5K then it does not matter. My point is that the name on the oil filter means nothing, it is about what is inside the oil filter. 2 answer your question, just do this:
Google, Mobil 1 1 oil filters Bitog, and see what comes up.
Mobil 1 oil filters are no longer made by M+H! Highline Warren(new distributor) seems to be using VAFI and a S Korean manufacturer to build the new Mobil 1 filters and the quality is excellent now.
Thank you. I'll look it up. I would appreciate your opinion, but I'll do the research. I run them for 7k miles typically. highway miles. I thought I heard that they changed manufacturers, we shall see.
You are welcome and you can do your research and see what you find. There is an Oil Filter expert on this board that you might find in your search.
they’re much better now. however, you can get something just as nice in a premium guard XL, easily found as carquest premium, microgard select etc.
where are you looking them up ?? I don't think there is anywhere other than here to find info on the new ones.
they are right here:
I could be wrong but if you want to make sure you get the new ones, look inside the center tube. If it has louvers, it's the old style. The new ones have holes punched instead of louvers. There may be old stock still sitting on shelves.
It should serve you well for the 7k mile oci you indicated below. You could save money and just use a basic filter for that mileage. ST, Fram orange, ACdelco, puro classic etc. or use the M1 for 2 ocis
Another thing that's new is the business end is covered with plastic, at least the one I bought that's the same P/N as the filter pictured in a post further up. I for one am a fan, the more crud kept out of the filter the better.
  • Like
Reactions: GW.
I heard they are soon going to black plastic to deter the weird people breaking the box seal to shine a flashlight in them 😵‍💫
Been using the 108A on my Triumph motorcycle for many years. Sits low on the engine as expected so extra exposure to the elements, stones etc.. Has always served me well, no issues. Will continue to be my preferred choice as availability allows.
