My truck's cap calls for 5w30 oil. I run Mobil 1 Extended Performance around 10k-12k a year, and normally fill with Mobil 1 Extended Performance 5w30.
When going to buy a 5 quart jug at walmart (which is out of my way) all they had was Mobil 1 Extended Performance 10w30, so I bought that.
Based on this information, 10w30 seems nearly the same as the 5w30 blend:
Mobil 1 Extended Performance 5w30 5W-20 10w30
SAE Grade 5w30 5W-20 10w30
Viscosity @ 100ºC, cSt (ASTM D445) 10.6 8.9 10.2
Viscosity, @ 40ºC, cSt (ASTM D445) 59.8 49.6 63.7
Viscosity Index 169 161 147
Sulfated Ash, wt% (ASTM D874) 0.8 0.8 0.8
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.0 2.75 3.1
Pour Point, ºC (ASTM D97) -40 -42 -39
Flash Point, ºC (ASTM D92) 230 230 232
Density @15.6 ºC g/ml (ASTM D4052) 0.851 0.850 0.856
Safe to assume I can run this for my usual year, enduring NY winters that can reach a couple degrees below 0?
