Price is similar. ESP goes $37+filter in AZ or AAP.Well after all the replies and searching BITOG threads exhaustively and as was stated numerous times you cannot go wrong with either one. I have decided to go with Valvoline 5w30 XL III being it is available on Valvoline’s website for a great price vs the ESP. Plus Valvoline is giving away a free hat with purchase..
Dad used that oil religiously. LolThanks for the replies everyone. I do understand that there are no discernible differences between both oils. But like everyone else here I was just looking for real time information, opinions, suggestions from members who are more lube savvy than I. As far as the warranty concerns I do maintain my vehicles religiously at 5K OCI’S so I would hope that would be good enough at keeping the warranty denier’s at bay. As you stated if you went to a dealership today and asked anyone in the service department about ILSAC, ACEA, or API they would most likely not have a clue. I just may put that to a little test next time I go to dealership I will bring a can of the oil I started out with and ask if this is ok.
Glad to here that the Valvoline is working out for you. But I actually ran down to the AZ store yesterday before ordering the Valvoline. Well they were loaded up with 5w30 ESP so I decided to take a few jugs home with me. Figured I would try this out first seeing that is readily available right close to home.Not directly answering your question here, but I decided on the Valvoline Euro 5w30 XL-III for my new Mazda CX-9 (2.5L turbo) after some research. I was considering the same Mobil 1 you are and one of the Pennzoil Euro 5w30 (I forget the difference between the L and LX). At a little less than 15K miles, I've only had 2 oil changes (5K OCI), but all indications are that is working fine.
Full disclosure, I think there was a BOGO or similar on the Valvoline website at the time, so that may have swayed my decision making a bit, and I bought a few 5qt jugs for my CX-9 and my college son's GDI Hyundai Sonata.
Walmart is now the place to get ESP in the 0w30 flavor...about $10 cheaper per 5 quart jug near me compared to AZ or O'Reilly.At my AZ they've got the XLIII as well as two flavors of Mobil 1 ESP, the 5w30 and the 0w30. For the same price as the XLIII for a 5qt jug, I think I'll go with the 0w30 ESP for my next OCI on the Benz.
It has had a strict diet of Mobil 1 ESP 5w30 for the last 40k-ish miles and it's performing great, but I do like the slight improvement in the cold start flow of the 0w30 especially for the upcoming winter in the Midwest.
Plus the API SP engine test requirements. The fact that it doesn’t qualify for the bench test requirements is typically regarded as a benefit, not a detriment.ESP 0w30 is API SL whereas 5w30 is API SP if that makes a difference. I’m seriously thinking about running either the Valvoline XL-III or the Mobil 1 ESP 5w30 in my Toyota. Likely the Valvoline XL-III because the website says that it also exceeds ILSAC GF-6A requirements so it meets all specs for Toyota.
It does. ESP 0W30 has better additive package. Higher ZDDP.ESP 0w30 is API SL whereas 5w30 is API SP if that makes a difference. I read somewhere that it was a matter of having a little too much phosphorous content which wouldn’t not make a practical difference. I’m seriously thinking about running either the Valvoline XL-III or the Mobil 1 ESP 5w30 in my Toyota. Likely the Valvoline XL-III because the website says that it also exceeds ILSAC GF-6A requirements so it meets all specs for Toyota.
