Mobil 1 Advanced Full Synthetic 0w20
Houston,TX
Batch number 11019A08A 6184
Code
Sample Date 2/14/2019
Sample # 40555
Lab #
Analyst JAR
Unique ID 40555
Wear Status 0
Cont Status 0
Chem Status 0
Unit Usage
Oil Usage
Oil Added
Aluminum 0.48
Antimony 0.94
Barium 0.01
Boron 91.98
Cadmium 0.44
Calcium 921.43
Chromium 0.01
Copper 0.02
Iron 0.5
Lead 0
Magnesium 494.97
Molybdenum 93.9
Nickel 0.04
Phosphorus 649.07
Potassium 0.85
Silicon 6.27
Silver 0
Sodium 6.94
Tin 0.98
Vanadium 2.24
Zinc 839.26
Manganese 0
Titanium 0.08
Add Depletion 101
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
Cnts >4 7,564
Cnts >6 1,919
Cnts >10 466
Cnts >14 169
Cnts >18 22
Cnts >22 10
Cnts >26 3
Cnts >32 1
Cnts >38 0
Cnts >56 0
Cnts >70 0
ISO >4 20
ISO >6 18
ISO >14 15
Glycol Vol 0.1334
IR Fuel
IR Oxidation 7.16
IR Soot
IR Nitration 1.09
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 14.12
Visc 40C 42.6
Visc 100C 8.4
Visc Idx
MxD Ox >50 0
Total Acid
Total Base 8.59
Foam Tend 1
Specific Gravity .841
Solids Vol
MxD Ot >20 1
Fuel Vol
PC Vol < 6u 0.34
PC Vol 6-14u 0.59
PC Vol >14u 0.42
Soot LEM/TGA 0
Soot Vol
MxD Ot >25 0
PPM Water 1
Originally Posted by Bottom_Feeder
What's 'AFS'?
I wonder if he meant AFE , perhaps AFS means advanced full synthetic. I've seen that phrase in some M1 literature.
EDIT: I just saw he answered as i was typing this.
Taking a look at the bottle it can be called either one, since the bottle says both. But I expect everyone knows what the op is talking about.
No, TestOil does not measure out to two decimal places. While cool, I think it's totally unnecessary considering there is inherent variation in the measurement anyways.
If you look at the last couple VOAs I posted, those were done by TestOil. They appear to be a very thorough lab, but you pay for it. An oil analysis with particle count runs $48 for a single sample. If you did 30 or more samples per month, they drop the cost significantly per sample. It's great if you're using it as a PM system for work! Angela is who I've dealt with at TestOil and her customer service is amazing.
Absolutely not. To thin for the ecoboost. Im running 0w40
These results are from my lab at work. Thats just how it outputs the data. We use testoil for verification of accuracy periodically.
