I am beginning to wonder all of a sudden about this high lead readings of late.The statement: the use of leaded oil additives would be what exactly.Is it the gas or is there something being added to our cars engine in the synthetic oil thats caused this.We used to rarely have these kind of posts where the lead shoots up like this.Have the testing companys gotten together to give us something to worry about.
Perhaps the extended OCI has something to do with it but the additive route seems the most likely reason. Here is another current OCI that has given us a reason to be concerned. I started running mobil 1 at my second oil change around 6,000 miles. I changed it every 3000 miles until last year when i figured i might as well try and extend it to 7500 which is what the Subaru recommends. My first analysis was done after 37,624 miles with 4427 miles on the oil. The numbers were all below normal so i let it go to 6261 miles this time. All the numbers are up quite a bit this time.
code:
6261 / 4427 / Uni avgALUMINUM 4/ 3/ 3CHROMIUM 1/ 1/ 1IRON 14/ 9/ 8COPPER 5/ 4/ 5LEAD 7/ 1/ 5TIN 0/ 1/ 1MOLYBDENUM 92/ 59/ 71NICKEL 0/ 0/ 0MANGANESE 0/ 0/ 0SILVER 0/ 0/ 0TITANIUM 0/ 0/ 0POTASSIUM 0/ 2/ 1BORON 155/ 130/ 99SILICON 15/ 11/ 7SODIUM 3/ 4/ 6CALCIUM 3195/ 3047/ 2577MAGNESIUM 18/ 13/ 114PHOSPHORUS 874/ 687/ 778ZINC 1084/ 706/ 917BARIUM 0/ 0/ 06261 / 4427 Sus Viscosity 60.5 / 57.5 Flashpoint 380 / 370 Fuel % < 0.5 / < 0.5Antifreeze % 0 / 0Water % 0 / 0 Insolubles 0.3 / 0.4
Feedback from Blackstone: Silicon increased a little, and along with it, engine wear. The oil was run about 1,800 miles longer than the first sample, and that accounts for most of the increased wear. Silicon can often show problems developing at the air filtration, so we suggest checking this system on your engine. These metals are not enough above universal average levels to show a mechanical problem developing in the engine. No fuel dilution or coolant was found and insolubles were low showing good oil filtration. Other than the silicon, nothing unusual showed up at 43,885 miles.
The cut & paste didn't come out well but the lead was what were concerned about.
