Used a Purolator classic filter, wear metals were very close to average according to Blackstone but iron and copper seemed a bit high for this interval? I am now running 0w-30 Mobil 1 for winter and thinking a 7500 mile interval next time. Thoughts? I run the G6 to redline probably 5-10 times a week but otherwise not driven too hard, 50-50 highway/city over a 3 1/2 month interval. Thanks.
TGM 3.5L V-6MAKE/MODEL: OIL TYPE & GRADE: Mobil 1 5W/30
UNIGasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 5,489 Miles, 39,889 on unit
ADDITIONAL INFO:
COMMENTS MATTHEW: Go ahead with 7,500 miles next time on either the 0W/30 or 5W/30 oil. Your engine looks great in its first report. Averages are based on about 5,500 miles on the oil. You ran a similar interval to averages,
and your numbers couldn't get much better than they are. You almost never get perfectly average numbers since engines wear differently based on operational factors, but your first sample does look quite good. The TBN of 3.1 shows active additive left and no contamination was found in the oil. See you in 7,500 miles.
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 5,489
UNIVERSAL
AVERAGES
MI/HR on Unit 39,889 UNIT /
Sample Date 10/20/12 AVERAGES
LOCATION
Make Up Oil Added 0 qts
ALUMINUM 4
CHROMIUM 1
IRON 15
COPPER 16
LEAD 7
TIN 0
MOLYBDENUM 72
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 43
SILICON 6
SODIUM 5
CALCIUM 1185
MAGNESIUM 803
PHOSPHORUS 666
ZINC 780
BARIUM 0
Values
Should Be*
PROPERTIES
SUS Viscosity @ 210°F 58.5 55-62
cSt Viscosity @ 100°C 9.80 8.8-11.1
Flashpoint in °F 410 >365
Fuel % Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.2 TBN 3.1 >1.0
TAN
ISO Code
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 www.blackstone-labs.com
©COPYRIGHT BLACKSTONE LABORATORIES 2012 LIABILITY LIMITED TO COST OF ANALYSIS
ADDITIONAL INFO:
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 5,489
UNIVERSAL
AVERAGES
LOCATION
ALUMINUM 4
CHROMIUM 1
IRON 15
COPPER 16
LEAD 7
TIN 0
MOLYBDENUM 72
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 43
SILICON 6
SODIUM 5
CALCIUM 1185
MAGNESIUM 803
PHOSPHORUS 666
ZINC 780
BARIUM 0
Values
Should Be*
PROPERTIES
Water % 0.0 0.0
TAN
ISO Code
