Hey John, good to hear from you. I was hoping you where going to respond to my thread. This is a page from Mobil 1. I did contact them and they advised that Mobil 1 has 1200 ppm of zinc and would be great for my old school valvetrain. I did not ask about the other additives. Its HTHS is 4.5. Like I said, I love the way my car performs on this oil. I can feel the difference. Start easier and revs a heck of lot faster. Just awesome glued to the seat performance.
Some other Pontiac freaks like me noted that there cam went flat after switching to Mobil 1 but this was some years ago. However they didn't mention what viscosity. According to Mobil 1, the 15w50 is the only weight that has the extra zinc. Well this be a good choice for my 400? Should I be concerned with the slightly louder valvetrain noise than before?
Product Description
Mobil 1 15W-50 is the most advanced performance synthetic engine oil designed to provide the cleaning power, wear protection and performance reserve to keep engines running smooth and clean.
Features and Benefits
Mobil 1 15W-50 is formulated with SuperSyn, an extra high-viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired. Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
Key features and benefits include:
Features
Advantages and Potential Benefits
Fully synthetic formula with SuperSyn Technology Helps prevent deposits and sludge build-up to enable long engine life Excellent overall lubrication and wear protection performance for all driving styles
Outstanding thermal and oxidation stability Outstanding performance during the maximum oil change interval recommended in a vehicle’s owners manual
Extra anti-wear additive Extra protection for severe service
Applications
Mobil 1 15W-50 is recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
Mobil 1 15W-50 is recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required in newer generation vehicles
Mobil 1 15W-50 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Back to Top
Specifications and Approvals
Mobil 1 15W-50 meets or exceeds the following industry specifications:
API SM,SL,SJ,EC,CF
Typical Properties
Mobil 1 15W-50
SAE Grade 15W-50
Viscosity, ASTM D 445
cSt @ 40º C 131.2
cSt @ 100º C 18.1
Viscosity Index, ASTM D 2270 154
Sulfated Ash, wt%, ASTM D 874 1.21
HTHS Viscosity, mPa•s @ 150ºC ASTM D 4683 4.50
Pour Point, ºC, ASTM D 97 -39
Flash Point, ºC, ASTM D 92 235
Density @15º C kg/l, ASTM D 4052 0.87
Back to Top
Health and Safety
Based on available information, this product is not expected to produce adverse effects on health when used for the applications referred to above and the recommendations provided in the Material Safety Data Sheet (MSDS) are followed. MSDS's are available upon request through your sales contact office, or via the Internet. This product should not be used for purposes other than the applications referred to above. If disposing of used product, take care to protect the environment.
