By "scraping" I just mean that there must be some metal to metal contact, where the hydrodynamic film is breaking down--that's why the zinc and phosphorous are being depleted.
Motorcycles are normally much, much harder on motor oils than cars are, so I figured the UOA's were relevant to this discussion.
The 60 psi of oil pressure may mean that you're not moving the oil fast enough. I recently read on an oil website (I go to so many I can't remember which one)
that too much oil pressure could be an indication of too much viscosity.
But as I mentioned, this is merely a layman's interpretation--we await expert comments from someone here.
Things will almost certainly settle in. I don't know why (for sure) but my instincts keep telling me... dino... dino... dino... Maybe it's the age of the engine. Maybe it's this "instilled" idea that dino is best for break-in (I realize you did that, but perhaps just not long enough in this case).
If all you had was high wear metals, we could surmise that the Mobil 1 was just "breaking loose" sludge or film (which contained these wear metals) from the initial break-in. But with the lower zinc and phosphorous I'm just thinking it's possible that there is still some breaching of the hydrodynamic film going on there.
I could be totally wrong here, so don't put a lot of stock in what I'm saying. I would be most interested in the follow up UOA.
Have you considered going back to the Delo? GOBS of zinc and phosphorous in that one.
Or even good old 10W30 Pennzoil might be just the ticket here. A lower oil pressure, somewhere in the 40 to 45 psi range may mean more flow.
Dan
[ March 08, 2005, 10:54 PM: Message edited by: fuel tanker man ]
