Mobil 1 10-40 High Mileage
Somerset County, PA
Hot off the e-mail - a VOA of M1 10-40 High Mileage, SL/CF rated.
RON: Nothing unusual found in this virgin sample of 10W/40 oil. The TBN read 9.6, so you're starting out with a high level of active additive, and this oil should be a good one for running long intervals. No moisture found. The trace of insolubles probably should not be there, but it's not hurting anything, either. Note the 6 ppm silicon that you're starting out with. (Wonder why that's in there? According to Blackstone, it's an anti-foam agent. The last few samples of everything I've sent them comes back with a "high silicon" note. I don't live in the desert or anything.
) You'll need to subtract this from your silicon level in used oil samples to get your true silicon level.
MI/HR ON OIL: —
MI/HR ON UNIT: —
DATE: 10-2-08
ALUMINUM: 0
CHROMIUM: 0
IRON: 2
COPPER: 0
LEAD: 0
TIN: 0
MOLY: 93
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 1
BORON: 231
SILICON: 6
SODIUM: 5
CALCIUM: 3275
MAGNESIUM: 17
PHOSPHOROUS: 860
ZINC: 1035
BARIUM: 0
SUS VISC. @210F: 77.4
Cst Visc. @100C: 14.88
Flashpoint: 435
Fuel %: —
Antifreeze %: —
Water %: —
Insolubles %: TR
TBN: 9.6
TAN:
ISO Code:
Yep, it's the old Mobil 1 from about 3 years ago. Looks like ASL/ATM Amsoil.
