Mobil 1 0w40 Calcium Levels
CA
I just received a used oil analysis on a fill of Mobil 1 0W40 where the Calcium level was 3687ppm. I was surprised by this number, so I had the lab retest - and it remained about the same: https://bobistheoilguy.com/forums/threads/2016-mb-e350-mobil-1-0w40-18-092-miles.370385
I found a VOA from 2020 where the Calcium level was 3437ppm: https://bobistheoilguy.com/forums/threads/mobil-1-0w40-euro.332273/
I also found an used oil analysis from 2022 where the Calcium level was 3771ppm: https://bobistheoilguy.com/forums/t...4k-mi-oci-144k-mi-2013-cadillac-cts-v.364117/
However, most used oil analysis I've seen show the Calcium level to be about 3000ppm. Was there a brief time period where Mobil 1 0W40 was using ~3500ppm of Calcium in its formulation?
Between variances in blending, methods of sampling, and margin of error of the ICP, it can vary quite a bit. A +/-15% swing isn't unrealistic between different batches tested in different machines. The ICP alone is +/-5% with good calibration, thorough flushing/cleaning, and slower, more precise measuring method. The ICP at the UOA labs, shooting samples through as fast as possible, can fair worse, plus possible carryover from previously run samples.
In PDS you will see language: typical values.
Different batches can produce different results.
We're talking about parts per million here. Look at 3000 ppm and 4000 ppm as 0.3% and 0.4% respectively of the oil's total content. Comparing the VOA and UOA in the OP, that's 0.3437% vs 0.3771%.
We're talking about parts per million here. Look at 3000 ppm and 4000 ppm as 0.3% and 0.4% respectively of the oil's total content. Comparing the VOA and used oil analysis in the OP, that's 0.3437% vs 0.3771%.
That's beside the point - almost every other Mobil 1 0W40 used oil analysis is at 3000ppm. Something is amiss here.
Again, it could be a batch, left over oil etc.
Different labs could return different results.
I would not bet on $30 lab analysis as being dead accurate.
We're talking about being off by more than 15% - over 500ppm difference.
I'm the first to admit that used oil analysis are of questionable accuracy, but they're generally not this bad - especially if the sample was ran twice.
I can tell that you're a chemist and not a microbiologist. LOL.
I look at chemistry results on drugs on a regular basis. Between the method variability, the blending variability, the in-use variability, +/- 15% seems about the best that can be achieved on a used oil analysis. Nothing about these results makes me think there is any lab error or excessive method variability. I'd be surprised if they performed the extensive method validation and change control management and instrument calibrations that we perform for drugs.
it depends on the method, instrument, sample prep, etc. of course. I would guess +/- 15% at concentrations as high as these is not great. There are environmental testing labs that can report ppt levels of PFAS now.
