Mobil 1 0w-20 SM VOA
Bangor, Maine
Aluminum-----0
Chromium-----0
Iron---------1
Copper-------0
Lead---------0
Tin----------0
Molybdenum--93
Nickel-------0
Manganese----0
Silver-------0
Titanium-----0
Potassium----1
Boron-------74
Silicon------3
Sodium-------4
Calcium---2080
Magnesium---13
Phosphorus-770
Zinc-------871
Barium-------0
Viscosity---54
Flashpoint-440
TBN--------9.9
Forgot the date code for this sample. It is X18A6 5371, which is January 18, 2006 (I also checked with a black light.) The second letter stands for the month and the digits befor the letter give the day of the month, the 6 after the A is for 2006
Yes, the SL is probably better if you can find it, I just wanted to let people know what one sample of the SM looks like.
I found an old VOA from Blackstone (which is where my VOA was done) from Aug 03, so a comparison from the same lab can be done, I am not sure when the oils changed over to SM.
-----------Jan-06----Aug-03
Aluminum-------0----------2
Chromium-------0----------0
Iron-----------1----------2
Copper---------0----------0
Lead-----------0----------0
Tin------------0----------0
Molybdenum----93---------67
Nickel---------0----------0
Manganese------0----------0
Silver---------0----------0
Titanium-------0----------0
Potassium------1----------0
Boron---------74--------198
Silicon--------3----------3
Sodium---------4----------7
Calcium-----2080-------2892
Magnesium-----13---------21
Phosphorus---770--------862
Zinc---------871--------979
Barium---------0----------0
Viscosity-----54---------54.9
Flashpoint---440--------470
TBN------------9.9-------11
Big difference in flashpoint, Moly, B, Ca, P, Zn, the old stuff looks good to me, but I will keep you updated on how the new stuff looks in my Prius on the used oil analysis forum. Should be rreaching 5000 miles pretty soon, I plan to sample and keep iit going for 10000 at least, things looked ok at 2400.
Better format. I learned the code trick.
Code:
Blackstone Labs Virgin Oil Analysis
Mobil 0w-20 SM
Date Code X18A6 Jan. 18, 2006
Date Dec-06 Aug-03
Alum 0 2
Chrom 0 0
Iron 1 2
Copper 0 0
Lead 0 0
Tin 0 0
Moly 93 67
Nickel 0 0
Mang 0 0
Silver 0 0
Ti 0 0
K 1 0
Boron 74 198
Si 3 3
Na 4 7
Ca 2080 2892
Mg 13 21
P 770 862
Zinc 871 979
Barium 0 0
Visc 54 54.9
Flash 440 470
TBN 9.9 11
Thanks for the VOA, i'm running this as we speak.
This was the best oil in terms of smoothness that I've used. (SL version). I'd like to try the new Havoline 5w-20 8.0 cSt oil.
Quote:
I would think this oil would be fine in the 06 Civic and you would probably get better gas mileage than a xW30.
Yes. I posted that before my Sentra was totaled. Now that I have the Civic and it specs 5w-20, the M1 SL 0w-20 is going in next!
Funny how things work out
Brian
