This was my first time doing anything like this. My reason was because I believe I have a stuck oil ring. If you don't feel like reading the story my question is: is it possible to end up burning more oil after clearing up build up on piston rings? Say the build up was contributing to it sealing. Or is that not likely? My car has a ton of miles and burns a quart in less than 700 miles, mostly all on one cylinder.
I did a 12 hour soak on my 363,000 mile accord. 2oz per cylinder. I expected the MMO to drain down overnight, but that wasn't the case. It took a good 5 minutes to get it started. I'm glad my starter has a lifetime warranty. When it did start, it was a white out. It was 6am so it was dark enough that I couldn't tell if it was just white smoke.
I came home that day, after 130 miles of driving, and put 2oz in each cylinder again. This time the car sat for about 26 hours. It started much quicker. It was daylight, the smoke was horrendous. I live near a road and it was screwing up traffic. People were coming outside of their houses to see what was going on. After 5 minutes of this I decided to take my smoke elsewhere. My honda looked like a DDT truck. After driving for a couple minutes the smoke cut down quite a bit, but my smoke trail had a noticeable blue hue to it. A constant blue/white trail followed me for the next 8 minutes before I came home and shut it off. I was concerned I damaged the oil rings. I went to run some errands 20 minutes later and had no smoke trail.
I feel like I should do this one more time and give it even longer to sit. But I'm not sure, this is uncharted territory for me.
