MMO 20% Rotella 15w40 (80%) 4650 Mi 2003 Deville
Originally Posted By: Jax_RX8
Originally Posted By: ronrackley
I'm OK on the 80%/20%. I put in 6 quarts of Rotella 15w40 for 80% of the 7.5 quart sump capacity and 1.5 quarts of MMO for 20%. It is the same concentration of MMO you would get with 4 quarts of regular oil and 1 quart of MMO in a regular 5 quart sump.
By "first formulation" I meant with the motor oil in the mix being Rotella 15w40 - their conventional oil - that I ran the last OCI with the MMO as opposed to the Rotella T Synthetic 5w40 that I normally run and that is in the car for a new OCI now. I used the conventional Rotella because I figured why waste money on synthetic oil for a maintenance cleanup run with MMO. I sent the sample in just for fun, but when I saw the wear metal numbers I decided that I would do a little more analysis to see if there is more to marvel over than I ever realized. I'm going to have this new RTS analyzed at about the same mileage and decide what to do from there. If the wear numbers don't look as good as they did this last OCI with the MMO, I'm going to repeat the MMO run to see if it agrees with the first one. I'm thinking that I'll do that with MMO in some RTS next time unless I talk myself into going out and buying some more conventional Rotella for science.
Aw, I missed that your current filI was with RTS.
RTS is a fine oil, and if you don't mind spending the extra, run it with the MMO. I did that with my old RX8 (now sold), which benefitted from a thicker oil, and very much liked the results.
How does MMO thicken up the oil? Do you mean after the lighter components evaporate? How did the car "very much like the results"? Did it have higher compression than comparable engines? How did you know it was so happy?
Sometimes when I'm rubbing her throttle plate I think I can hear my car moan.
I did not state MMO thickened the oil, it thinned it slightly, bu I started with a 5W40 oil and the car calls for a 5W20 - so my net result was more along the lines of a 30 wt.
No used oil analysis, but car ran smoother and quieter, like all of them I use MMO in. Anecdotal, yes, but I could tell a difference.
Originally Posted By: Jim Allen
...DOes MMO cost more or less than the oil it replaced.
About a dollar more per quart than the conventional Rotella 15w40 it replaced this time, but it would be about a dollar a quart less than synthetic if I ever wanted to do that. It is around $3.50 a quart at Walmart. It certainly does not have a "rip-off" price.
For what MMO does, they could probably sell a good amount of it for a multiple of that price if it had a high-tech sounding name instead of a stereotypical snake oil sounding name. I don't think it would ever occur to me to pick a bottle of something with a name like "Marvel Mystery Oil" or "Magical Mystery Juice" or anything like that off a shelf at WalMart and pour it into the engine of one of my beloved automobiles if I didn't already know what it was.
