I know you shouldn't mix types such as conventional and synthetic. But i have a bike that takes about a 1/2 quart over a gallon if i drain it real good. The oils i use comes in 1 gallon jugs and is quite expensive, and the quarts are even moreso at around $12. I hate to have to buy a gallon then spend another $12 on a single quart, and i have several quarts left over from various experiments with oil, so i wanted to know whether it's ok to mix as long as it's a small amount like 1/2 quart added to a gallon. I have some Mobil 1 V twin synthetic that i'd like to add to a gallon of motul 7100 full synthetic. I also have some Torco blend i'd like to add to it after i run out of the mobil 1. I have about 5-6 quarts of those 2 oils and i intend to use motul 7100 for now on so i'd like to use those up and in the process not have to buy extra quarts in addition to the gallons. Is that ok or is it not a good idea?
