Mixing atfs to achieve a target viscosity
MD
I have a Saab that takes 3309. There were multi-vehicle synthetic fluids a short time ago that were close to the 3309 viscosity, but now I find most multi-vehicle fluids to be Dex VI clones and consequently thinner. Today I mixed Castrol LV synthetic with their multi-vehicle import, 50/50. In theory the mix should be close to 3309 in viscosity. Any opinions?
No. That's dumb as [censored]. Buy 3309 fluid. Either from Mobil or Toyota. $40 bucks of fluid is cheaper than a transmission.
The Toyota dealer here sells Mag 1 ATF in their parts department right along side of the T-IV. Priced at $3.99 per quart.
Originally Posted By: Donald
Buy the right stuff. Don't play Mr. Chemist. Your transmission will reward you if you buy the right stuff.
More importantly, the transmission might give you four figures worth of punishment if you get things wrong.
I recognize that I can by T-IV from Toyota. The reason I'm doing mixing is because I'd prefer a synthetic, or partially synthetic, fluid. Both fluids say that they are suitable for T-IV applications.
More important to minor changes in viscosity, is the friction characteristic of a transmission fluid. That includes ATF, THF, engine oils and TO-4s, all where wet clutches are present.
Automatic transmissions are rarely at exactly 100C where the viscosity is published. My pick-up truck has a transmission fluid temperature gauge, and I was surprised to see how cold it runs.
Your mixing experiment is no different to someone adding a couple of liters of ATF into a transmission that was low on fluid. Nobody would drive all over town looking for the same brand that dripped on the garage floor.
Case in point; My Allison 1000 came FF with Dexron VI which I changed out @ 75K KMs to a thicker TES 295 fluid. The refill took 9 liters. The torque converter holds 4-5 liters that was left behind. Both fluids must be compatible with the transmission's frictional requirements.
I recommend no one take advice from this person. Low viscosity ATF is not compatible with 3309.
Well, Maxlife and Castrol multi, synthetic lv say that are suitable for Toyota T-IV applications. I'm dubious to an extent, that's why I mixed in a higher-viscosity compatible fluid.
Yeah, I decided to try the Valvoline because; it's available locally, cheap (in the jug size, anyway), claims to meet JWS-3309 and DOESN'T meet Dex-VI, or WS. Valvoline claims a synthetic base, but that doesn't matter a lot to me because the fluid gets changed (cooler line exchange) every 30,000 miles.
I will admit that I am a little leery of anything that meets every specification...
Originally Posted By: Astro14
If it helps, I tried Valvoline import multi vehicle in the Volvo XC. This stuff: http://www.valvoline.com/our-products/au...nsmission-fluid
Bought it in jugs from my local AAP. Did a complete flush. Car shifts great. With a viscosity of 6.9 @ 100C, it's pretty [censored] close to the Mobil 3309 of 7.1 @ 100C.
I agree. I can't find the Valvoline import multi vehicle in the gallon jugs anymore where I am. I'm looking into Shell Spirax S5. This seems to be the closest to a 3309 synthetic.
www.lubricants.petro-canada.ca/resource/...amp;language=en
ET16; I hope this download with all the cross references helps. SFU means suitable for use.
Dura-Drive is a "high viscosity" atf, and may be used where Dexron III-H was recommended.
Dexron III-H may be replaced with Dexron VI for improved economy, cold performance and fluid life.
Sorry about the baseball game.
Thanks!
Just buy the right fluid it's the same price as the valvoline stuff. Jesus [censored].
