I recently bought myself a Mitsubishi FTO - this is a small Japanese-market front-wheen drive sports car with a 2.0l V6 engine . Its has a 5-speed manual transaxle and the car has only 20k miles on it (its a very clean and 'tight' car so could even be genuine miles....).
Anyway, the engine, suspension etc is great. I have a small snag with the gearbox. Its rather 'notchy' when cold. When warm it tends to 'catch' third gear synchro when changing up 2-3. Strange thing is that I can downshift as fast as I like 4-3 or 3-2 and there is no problem, its perfect, its just the upshift where there is a problem.
If I change up slowly from 2-3 (with a pause at neutral for a second or two) then its OK. A fast 2-3 change at 4000 rpm gives a definite crunch as it goes into 3rd.
I changed the gearbox oil for Redline MT90 - this is the recommended grade for the gearbox (75W-90 GL-4 Synth.) - but no improvement. I also bled the clutch and checked its adjustment, but it seems fine. I feel sure that the car shifted much better when I first bought it - but I have no idea of the grade/spec of the oil that was in there (the car was imported to the UK from Japan and I don't have the Japanese service history).
Someone has suggested the cable linkages from the shift lever may need adjusting - is this a possibility? Would a thinner oil (e.g. 75W-85 or even 70W-80) give any improvement do you think? Or am I looking at a 'box strip and repair?
