Hello,
All I've been a mechanic for over 16 years and I've seen milky oil on vehicles from coolant mixing with oil. I had a customer bring in a power washer to me for repair for the pump not working. I replaced the pump and was going to fire the engine. I wanted to check the oil level and gas before firing. Checked the oil and it was milky color. How in the living **** can this happen? I asked the customer and they swear they only used some Walkmart brand 4 cycle engine oil. I'm thinking they had to of used something they wasn't supposed to for engine oil. I'm just curious if anyone else has ever seen anything like this. I'm sending it back with the customer as is with new pump but with no promises it will do anything. I'm just curious since I've not seen this. When i see. This i just flipped the dam thing over right there on the floor and I guess was in shock or what I was looking at. Maybe if they put the correct oil in it then it might be a good running power washer?
