Microguard and Mobil 1 Filters cut
California
The Microguard has nearly 8000 miles on it. I had intended to run it to about 6000, but circumstances intervened. Other than a somewhat stiff nitrile ADBV, it looks pretty good.
Pleats are pretty evenly spaced, even at the seam.
This is off of my old 2001 GMC work van, and I feel pretty good about this filter.
Next is the Mobil 1. This is a tiny little filter from my wife's 2010 Nissan Sentra. Also nearly 8000 miles on this one. ADBV was pliable, as you would expect, and I thought everything looked great.
Here's a size comparison with the MGL51036 from my van. The MGL51036 crosses to the AC-Delco PF-52.
Those pictures are fantastic! What camera did you use?
Samsung Galaxy Note 3
^^^ That would be the equivalent to a Napa Silver, not a Gold. I haven't seen one run that far either, looks great though.
Thanks for cutting and posting!
Originally Posted By: Bud_One
Is that a Fram bypass valve on the Mobil 1 filter ?
Yes it is, the same company makes them both.
Good looking filters.
You have to be pleased with that $4 and change Wix built O'Reilly Microgard.
That's possibly the best "value" oil filter out there.
I sure wouldn't ask Purolator, STP, or FRAM Orange to do 8,000 miles.
Thanks for taking the time to cut and post.
Are they both for the same Car / Engine?
Looks like you get much more Filter / Filter surface area with the microgaurd.
Also glad to see Microguard are no longer EXTRA GAURDs anymore.
Microgaurd did a very noble thing by having WIX . NAPA making there oil filters...
Im sure Honeywell / RANK was cheaper....
both filters look good, however I like the MICROGAURD... Just seesm like more filter.
