Originally Posted By: DdDd
Can somebody please point out to me where this magical unicorn of a micro filter is located on their cartridge filters?
Granted the sock method in cartridges needs some more evidence they work. When they bunch up, the hope is they turn black with tiny particles (catching them) as the soft polymer material snags particles, yet I can't be certain this happens enough.
The parallel path filtration is easier to see how it is effective. By inspection one sees the fluid paths. .... The sock isn't a parallel path unless its bunched up, & effective only when we confirm it snags the smaller stuff inside the foam polymer material. Two separate issues really, cartridge socks and spin-ons with discs.
As for the ability to go 30k miles (10k filters & makeup oil), it does appear all the chemicals in the DI package in a good synthetic would be shredded or chemically altered over that long a run, depending on how much short tripping is done and how much high-heat stress is applied.
... We may find that M1 Annual Protection and/or AMSOIL Signature Series would make it to 30k miles adequately using 10k Microgreens and makeup oil as needed. ............. The Oxnard government fleet has been using MicroGreens for years with cheap re-refined GroupII SN motor oil, and I wonder if their rings gum up !!!!
